adding lift or replace factory pump in tank
Old May 16, 2021 | 01:16 PM
marty welsh's Avatar
Talking adding lift or replace factory pump in tank
hello,,
having issues with 2002,,,this has happened several times now,,,start truck , runs for 30-40 seconds, dies,,try to restart,, nothing,,,then wait a minute or two,,then it starts.
hmmm, just replaced fuel filter ,,was dirty, i thought maybe this was issue.
then it did it again today.
so, i am thinking factory pump in tank is going or injector pump is going ,,and it is orginal vp44 pump..with 190,00!!!!!
i thought of adding lift pump so i dont have to drop tank, but from video i just wateched,,i still must drop tank....
any suggestions???
it is a stock truck ,,just a driver,,the lift pumps are double the price,,,??
thanks...
Old May 18, 2021 | 09:14 AM
Check for codes, to see what the problem is rather than just replacing parts, as some of the parts you listed are big $$$.
Old May 20, 2021 | 12:47 PM
Talking
first ,,thanks for reply,,,
i was at oreillys a few weeks ago ,,and ask if they could check truck for codes,,,guy ask if i had alerts or icons on,,i said no,,as i dont,,,so he said then nohting will show up if they are no icons light up??
i have fuel pump on motor not tank,,figured that out,,,it was replaced about 10-12 years ago...thought would be cheap item to start with.
hallio217
13
Jan 7, 2014 08:51 PM
Ikes91
15
Jan 6, 2014 11:41 PM
megafast
Jun 7, 2007 09:51 PM
Tree DR
17
Apr 29, 2006 10:21 AM
tfarmer96
Jun 12, 2005 10:50 AM
