ABS and brake light
Old Oct 23, 2012 | 05:56 PM
DodgeCowboy's Avatar
DTR's Cow Boss
ABS and brake light and PO 0230
So today headed to check cows the darn abs and brake lights out....noticed I have a inner front u joint out pretty sure that's the abs & brake light issue,but I also got the po 0230 code? I have the fass ddrp with about 20psi idling and around 10-12psi cruising. What gives am I about to buy a injector pump and inner wheel bearings or should I just disconnect the fass and clean the connector??? Could the code just be there because of the vss code because I have not check engine light just the abs an brake..............
Old Oct 28, 2012 | 06:51 AM
DTR's Cow Boss
For what its worth two front inner u joints and a passenger side wheel bearing later no abs and no brake lighjt,as for the other code put a new relay in per the techies at fass and all seems well I still have great fuel pressure so hell with it.
Old Oct 29, 2012 | 08:29 PM
iwhitne's Avatar
I know on the 1500's the brake and abs light could be triggered by a dirty sensor on the rear pumpkin.. but not sure if it's the same on the cummins
fitzydog
21
Oct 11, 2017 12:09 PM
Joey-D
Dec 12, 2011 12:52 PM
BigBore050
Mar 9, 2010 11:46 PM
polaris800sp
Apr 7, 2009 10:08 AM
mr T
Feb 24, 2007 06:42 AM
