Old Mar 30, 2003 | 06:57 AM
  #46
Diesel Freak's Avatar
Re:NV 5600 failures
6 liters? wow, that's 6.3 Quarts!<br><br>NVG calls for 4.5 quarts<br><br>I filled up with 5 quarts<br><br>oil issued from the check port at less than 4.5 quarts...so I filled it through the top PTO cover bolt mentioned earlier.
Old Mar 30, 2003 | 07:32 AM
  #47
Pit Bull's Avatar
Re:NV 5600 failures
I'm going to change my fluid at around 50K miles. That's going to be over 2 years from now. I hope you guys have this fluid thing sorted out by then
Old Mar 30, 2003 | 08:57 AM
  #48
KwikKurt's Avatar
Re:NV 5600 failures
1. Scotty, What color sweater did you have on the Day of Trans Failure ??? (Or did you forget it compelety! : )
2. If it wasn't the required [shadow=blue, 2, 300]High Torque Blue wool[/shadow] :'( ..... Did it also clash with your seat covers????
Sometimes you Kanuckians surprise me by looking right past the Obivious!!!!
Old Mar 30, 2003 | 09:03 AM
  #49
AaronT's Avatar
Re:NV 5600 failures
On my NV4500 synthetic was recommended by chrysler. I got into a discussion with my dealer on this and the NV5600 oil recommendation. They said they were told by Chrysler to not use synthetic, only part # 4874464 (non synthetic). None of this makes sense to me anymore. This oil states on bottle that it is specially formulated for the NV3500. Go figure on this, no one seems to know or can provide a real for sure answer. I have contacted New Venture Gear for the last couple of weeks, but no response as yet.
Old Mar 30, 2003 | 09:44 AM
  #50
P Kennedy's Avatar
Re:NV 5600 failures
Aaron your right it is confusing except DC only recommends a 75-80 synthetic transmission oil (not hypoid) that they have in Mopar bottles with their part # for the NV4500. The NV5600 also uses a synthetic oil that has their spec and part # but is a lighter oil. Also we have put a 90 degree pipe elbow on all the NV4500's screwed into the filler hole and the plug into the top of that which will give you a 1 quart higher oil capacity which allows a bearing in the front to be properly lubed even at idle. Getting oil into the filler is a pain and must be done slowly but you will find a the tranny will run cooler and usually quieter with this mod. PK
Old Mar 30, 2003 | 10:12 AM
  #51
Pit Bull's Avatar
Re:NV 5600 failures
Sounds like when it comes time to change the lube in the old NV5600 you don't want the local Dodge dealer to do it since it can be new to them and some what complex.
Old Mar 30, 2003 | 10:31 AM
  #52
AaronT's Avatar
Re:NV 5600 failures
[quote author=Pit Bull link=board=4;threadid=11912;start=75#122151 date=1049040749]<br>Sounds like when it comes time to change the lube in the old NV5600 you don't want the local Dodge dealer to do it since it can be new to them and some what complex.<br>[/quote]<br>Pitbull I would say you have hit the tranny on the head so to speak.
Old Mar 30, 2003 | 05:36 PM
  #53
AaronT's Avatar
Re:NV 5600 failures
I just received this email from NVG Sales.<br><br>NVG Sales<br>It is still made. Same fluid, different Corporation name. It is now made and distributed by Shell, who bought Texaco.<br><br>NVG developed and validated the NV5600 transmission with the Texaco Synchromesh Transmission Fluid Code 1874 MTX. We have not tested nor had experience with any other fluid. NVG will not condone the use of alternative fluids in any of our products.<br><br>Mopar Part No. 52107548<br>In the United States, GM part #:12345349 Synchromesh Transmission Fluid.<br>In Canada, GM part #: 10953465 Synchromesh Transmission Fluid<br><br><br>
Old Mar 31, 2003 | 10:56 AM
  #55
BigBlue's Avatar
Re:NV 5600 failures
You were saying that the snychros need friction to work. Well, what if there is to MUCH friction in the snychros? Causing them to drag and rub and grind. That could be another problem. The additive may help restore that balance of friction and slipperiness(sp).
Old Mar 31, 2003 | 03:05 PM
  #57
Pit Bull's Avatar
Re:NV 5600 failures
I guess the saying is true. &quot;It's better to be lucky than smart&quot; I have one of the last 2002's made. July 2002
Old Mar 31, 2003 | 07:57 PM
  #58
AaronT's Avatar
Re:NV 5600 failures
Today I tried to get the NV5600 trans fluid from Mopar dealer and gave the following Mopar Part No. 52107548 as quoted from NVG. The dealer told me no such # exists. Now ain't that a hoot.
Old Mar 31, 2003 | 10:27 PM
  #59
Pit Bull's Avatar
Re:NV 5600 failures
[quote author=AaronT link=board=4;threadid=11912;start=90#122823 date=1049162250]<br>Today I tried to get the NV5600 trans fluid from Mopar dealer and gave the following Mopar Part No. 52107548 as quoted from NVG. The dealer told me no such # exists. Now ain't that a hoot.<br>[/quote]<br><br>Hey what do you expect, it's a lifetime fill fluid They don't need a part number because it never needs to be replaced :'(
Old Apr 1, 2003 | 08:08 PM
  #60
KwikKurt's Avatar
Re:NV 5600 failures
[quote author=AaronT link=board=4;threadid=11912;start=45#122823 date=1049162250]<br>Today I tried to get the NV5600 trans fluid from Mopar dealer and gave the following Mopar Part No. 52107548 as quoted from NVG. The dealer told me no such # exists. Now ain't that a hoot.<br>[/quote]<br><br>Aaron, That looks like the GM (General Motors) Part# for the same fluid. Many CTD owners started buying the Trans fluid from GM to save BIG$$$ then GM raised the price. I still think it's cheaper than the 5 Star Dealers....<br><br>BUT Don't tell Scotty... Let him search around for it alittle longer it will keep him and his GF Grill busy and out of our Emails... For a while I hope!!! ;D
