6spd with 315s and 3:55s i need some info.
im thinking about changing from 4:10s to 3:55s and im running 2200 at 72 in 6th now, and i think it will be around 1700 with the 3:55 is this correct or close?
what rpm do you guys run in 5th because i dont think i can pull my camper at 1700. i do run 100 highway miles a day ,no trailer and it would be great to run 1700 instead of 2100- 2200.
315's, 6 speed and 3:55's is a nice combo, I ran it for a couple of years and it was great.
In town it pulls you down a bit but highway was perfect. Actually after my 285's are cooked off, I'm going back to 315's.
Jeff
Jeff
6th gear is 1750ish at 68-70ish on the gps. 70-75mph is 1800ish.
3.55 or 4.10
I am running an automatic tranny with 3.55 right now and 315 tires. Its hard on the truck! I pulled a trailer with about 6500 lbs for 700 miles at 55-65mph twice in the last 3 months and my tranny got HOT! it finally went out 3 weeks ago. If you plan on doing an towing or dragging I would do some research because I am hearing nothing good about the 3.55. Some friends of mine told me the 3.55 seriously underdogs the tranny and makes it work a lot harder than it need to.
Its all opinion and speculation but has been proven in my situation to be right.
The point I'm making is your effective rear end ratio has been changed with the larger tires. Your ratio is somewhere around 330:1 and not 3.55:1. To much load on the tranny in OD.
3.73's at 1700 rpm would be 68 mph and 4.10's 57 mph with the 315's.
If your going to tow with the 315 tires you should change the rear or put the stock tires back on or tow in 3rd gear. (2200rpm at 65 mph) If you decieded to go with a 4.10 ratio, be prepared to buy another carrier for the rear as the 355 won't work. Gears and Carrier about 850-1100 dollars.
I'm pretty sure if you do tow in 3rd gear, the converter will not lock up.
The good thing is Cummins says, when towing you should maintain a speed
that is 2100 rpm or more.
Dave
