5 speed acting up...
Old Jan 29, 2007 | 04:18 PM
CTDYoungGun's Avatar
Alright, so here's the low-down...I had driven my truck 120 miles bac kto school yesterday problem free...as soon as I got to a stop light in town and shifted to neutral at a dead stop it wouldn't go back into gear...and i tried throwing it into gear HARD...so i shut off the motor, slipped it into gear and started it and took off...then it hung up in 2nd when i tried to shift to 3rd...with some coaxing (slamming it into neutral) it came out of gear...
...then it worked fine and hasn't acted up since...my best guess is a synchronizer or somethign floating around the tranny that shouldn't be...clutch linkage, master cylinder and clutch operate fine...
Old Jan 29, 2007 | 05:46 PM
aggiehorsepower's Avatar
It could be your hydraulic system. (Slave Cylinder)
Old Jan 29, 2007 | 06:53 PM
RickCJ's Avatar
When you have that problem don't force or slam anything, you will only make things worse $$$$$. Just shut it off and put in gear and restart. Sounds like hydraulics! or the clutch hub!
Old Jan 29, 2007 | 10:44 PM
yea...if i could see in the freaking housing i would check the throwout bearing...i really dont want to pull the tranny just to check the clutch unless it acts up again...i'd be doing it in a parkign lot here at college...
faster_than_ford
33
Mar 5, 2004 07:24 PM
Sonny
Feb 15, 2004 11:47 PM
SilverDodge
Feb 2, 2004 05:56 PM
Mrcummins24
19
Oct 1, 2003 11:43 AM
KC
Jan 10, 2003 11:25 PM
