4x4 issues
Old Nov 1, 2017 | 11:32 PM
LeftLaneGang's Avatar
4x4 issues
Hey gang, is there anyone around here who's pretty familiar with the interior of a 241HD t case? It won't engage the front driveshaft. I can't hear any growling, turning it by hand it's smooth, no filings in the oil. I checked my shift lever, full range of motion, clicks into each spot just fine. I still have low range, but same story. Is there a clutch in there to adjust? A shifter arm? Something vac operated? Some wisdom would be much appreciated.
Thanks
Old Nov 2, 2017 | 08:44 AM
patdaly's Avatar
Shift arm, but nothing to adjust. Sounds like perhaps a broken shift fork? I would think you could feel it not engage though.
Here is a power flow diagram so you can visualize it, as you see, pretty easy to trace.
Old Nov 2, 2017 | 11:30 AM
Busboy's Avatar
Do you mean the front drive shaft doesn't turn or just that you don't get 4 wheel drive? if it's that you don't get 4X4 then perhaps it's the vacuum operated axle disconnect that is the most common problem. Look for a vacuum line off on the drivers side up high close to the fire wall. Do your heater controls work? If not then you have lost your vacuum.
Old Nov 2, 2017 | 04:10 PM
It's' in the t case, cause I put a manual control on my CAD after wrecking some vac lines. I can feel something engaging when I go to 4H, but it feels too light, as if I'm engaged in 4H on the drive sprocket, but not putting power to the driven sprocket. Ive got half a notion that it's in the chaincase, whatever it is. I'll update as I know more, thanks guys.
EPCO
Apr 23, 2009 02:06 AM
horselady
Mar 30, 2009 11:48 AM
V.R.Wheeler
Aug 4, 2007 01:00 PM
ShooterMagavin
Jun 24, 2007 07:06 AM
Redneck_King
Mar 28, 2007 07:49 PM
