4wd question
Are your tires all exactly the same make and size along with being worn equal? Are you doing this on a hard surface such as pavement or hard packed dirt? Is your front and rear gear ratios the same? Any one ot those items will cause a delay in the 4wd dis-engagement.
It won't disengage while on pavement.It worked perfect when I first got the truck.Vaccume leak could be the problem.I'll have to do some checking and I'll post what I find.Thanks for the replies...Frank
Don't worry about it. The dash light is controlled by the axle disconnect. Your transfer case is not engaged and won't cause any damage. My '02 without the disconnect runs like that all the time. My '96 would keep the light on until I had made a couple of turns.
wrangler04
Jul 17, 2007 11:00 PM
VikingDiesel
Competition / Pulls / OffRoad
Dec 29, 2006 07:17 PM
95black2615
Dec 20, 2006 06:37 PM
1320
May 6, 2003 06:30 PM
