47re TC - jumping at speed
Old Apr 21, 2008 | 11:39 AM
lglamb's Avatar
I've had the TC unlocking at 45-50mph for a while, just not driving
it enuf to work the fixes yet.
Went out to blow out some leaves from the bed, it started
unlocking/jumping all over at around 80mph. Could this be the
same issue, or is it finally leading to swap time? Generally shifts
ok.
Fluid has been changed inadvertedly a couple times (cooler hoses
and connections letting go). Last refill was last fall. Fluid looks
ok now (pale red, not bad smelly). Fluid at top of hatch.
Thanks,
Lowell
2001 stock
Old Apr 21, 2008 | 12:00 PM
j-fox's Avatar
Most likely it is electrical noise.
Do a search on it.
clean all grounds. I just found the passenger battery ground-at the block was only snug.
One hand and it turned 1/2 turn.
thehemikid
Feb 25, 2021 12:45 PM
Munchies
Oct 19, 2006 06:09 AM
DODGEBRIAN
Apr 5, 2003 12:34 AM
pull superbee
Jan 30, 2003 09:26 PM
