47re PCM flash for better shifting
Old Oct 21, 2013 | 04:28 PM
floodlight's Avatar
I've had this RAM for 6 years and it always behave this way. When I get some good speed going and pay attention to how my RAM shifts it goes through fourth gear, and then the torque converter lock. I should feel all gears and then the TC lock. I just don't get any range in the fourth gear. Do any of you know if there's a flash to the PCM available that you make shifting better?
Old Oct 22, 2013 | 07:44 AM
patdaly's Avatar
Nope, 4th is OD LU, and it is a simple grounding function. ( PCM drags OD solenoid to ground )
Old Oct 22, 2013 | 01:01 PM
Tallguy67's Avatar
Pat,
I am not arguing, just asking. I always thought the shift events were 1 - 2 - 3 - 3tcl - 4 - 4tcl
Did I get that wrong?
Old Oct 22, 2013 | 04:06 PM
patdaly's Avatar
Mine was 1-2-3-TCLU-4 ( OD ) That was 100 percent stock.
The TCLU was a much bigger drop in RPMs than OD by several hundred RPMs, but I had stock converter.
TCLU is also a simple PCM bringing it to ground function, so other than MPH changes, nothing else a flash would change.
Old Oct 22, 2013 | 04:08 PM
patdaly's Avatar
67, just so it is clear, the only thing I think you are off is that the TC doesn't unlock for 4th, just remains engaged.......
Old Oct 22, 2013 | 04:51 PM
Tallguy67's Avatar
Pat,
Your response makes sense for what I have been wondering about all summer. I have not been able to feel a shift event after I leave 3tcl.
So what you are saying I am feeling is 1 - 2 - 3 - 3tcl - 4tcl.
I thought I was missing a shift event of some sort and ending up with 1 - 2 - 3 - 3tcl - 4
I was wondering why I was never getting tcl in 4th/OD.
Over lunch I was reading the tranny manual I have for 42rh / 46rh / 47rh and it sounds like there could be some conditions where you could be in 4th/OD without the torque converter locked up. Am I reading that wrong in the manual?
Wow - did I ever hijack this poor guys thread
Old Oct 23, 2013 | 07:53 AM
patdaly's Avatar
As for 4th without TCLU, I suppose it is possible, but I admit, I got rid of my Auto truck before I got completely familiar with its operation.
And yea, you are feeling after 3rd, the TC lock, which IIRC was about 5-600 RPM drop on Brownie, then later, 4TH/OD which was more along the lines of 2-300 RPM, and easy to miss.
Old Oct 23, 2013 | 11:05 AM
floodlight's Avatar
Thanks guys. I was hoping I could get what seems to be a 4th gear. It does feel like I have a gear missing before it goes in OD. Thanks again.
cramel
22
Oct 23, 2008 08:06 PM
Flattman
Oct 16, 2007 01:07 PM
CamperAndy
May 18, 2007 12:36 AM
8mpg
Apr 28, 2006 10:08 AM
04RAM2500
13
Dec 17, 2004 10:02 PM
