3cylinder high idle???
what year did they start doing that, i have an 02 with the older body style and ive not heard it go into the high idle, was that something that only came on the trucks with the auto tranny?
You can go to a Dodge dealer and get it activated. I had to shop around a bit to find one that would activate it on my 6 speed. A lot of dealers will only do it for the autos. Took the guy about 5 minutes and works great.
Click here. Print out the TSB. Hand TSB to the Service Writer and tell them you want the procedure done to your truck. My dealer never heard of it before either, but with the TSB in hand, I had the flash done in a few minutes.
if u have the TSB the dealer will do it. As stated a smarty will do it also but be warned once its downloaded to your rig you cant uninstall it with the Smarty as I found out the hard way, I need to go to a dealer to un-install it as it 3cyl high comes on all the time.
This is one reason why I avoid dealers--most of them are terrible to work with, and some can't even spell TSB.
Why would the type of tranny have anything to do with it? I have a stick and the high/3-cyl idle works just dandy on my truck. I'm not saying there couldn't be something I'm unaware of, I just can't imagine why a manual tranny would cause any issue with it.
Mike
Mike
Can you make the 3 cylinder work at 25* instead of 0*? I got the high idle installed with my buddies smarty. The high idle came on at 25*. I wish the 3 cylinder would work at that temp. Or maybe there is a reason it waits till 0*. I know the truck didnt warm up with just the high idle at 25*. Maybe its just a dumb question. I'm sure someone will educate me.. Thanks!
