2wd vs. 4wd pinion angle
Old Mar 2, 2007 | 07:16 PM
1919a4-a6's Avatar
I have a 99 2500 4wd. I'm wanting to change it to a drw 3500.I have been told that the 2wd rear housing has more nose down pinion angle than a 4wd because of shorter ride height.This makes sense to me,but any body know what the difference is? I can get a 2wd housing real cheap. My thought was to take it & make an angled wedge between the perch & spring to correct the angle.As long as the axle locating pin is long enough to go through the wedge & still engage the locating hole enough I think it will be ok. Do you think this would be safe? If so what is the difference in the angles so I can correctly make the wedges.Any good advice would be appreciated.
Old Mar 17, 2007 | 01:11 PM
HRDROKN's Avatar
If there was any real differences, it could easily be corrected with a wedged shim.
93Fury
Jan 17, 2009 04:53 PM
D45
Nov 11, 2008 06:19 PM
Harold Swanson
Jun 3, 2007 08:26 PM
Forrest Nearing
Off Road / 4x4
Nov 17, 2006 12:00 PM
