24V Lift Pump Installation
Old Oct 26, 2005 | 04:42 PM
rjones4's Avatar
I've decided my intermittent power problem is most likely the lift pump. Any links to a thorough explanation on how to do this? Thanks.
I will let you know if this is my root problem. Others have been describing the same issue of running good for a while then, no power for a while, then back to normal.
Old Oct 26, 2005 | 05:12 PM
crobtex's Avatar
Please fill in your truck info so we can see what your working on.
Have you tried hooking up a fuel pressure gage to see if it is for sure the lift pump? If it is, the change out is pretty straight forward. Just be sure you don't loose the o-rings and to "bump" the starter a couple of times after it changed.
Old Oct 27, 2005 | 12:38 PM
amartinson's Avatar
If you do end up replacing the LP, I used these instructions and they worked very well.
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old Oct 27, 2005 | 12:39 PM
amartinson's Avatar
BTW, if you don't have a fuel pressure gauge, get one. No 24V truck should be without one IMO.
Old Oct 27, 2005 | 01:23 PM
rfcom's Avatar
I just did mine last weekend and those instructions look about right. The factory service manual would have you do it from the bottom and the first thing it says to do is remove the starter. OK, that's second. The first is disconnect the batteries.
Jim
Brendan
Feb 21, 2010 04:11 PM
lconner1
Nov 11, 2009 12:23 AM
robox
Oct 7, 2005 01:31 AM
PDXDodge
Jan 18, 2005 04:10 PM
***gyro***
14
Nov 15, 2004 10:40 PM
