24v block numbers ?
Old Apr 15, 2011 | 11:20 PM
440727's Avatar
24v block numbers ?
I was looking at a 2000 Dodge 2500 today. I looked on the driver's side under the power steering pump above the oil pan and the tail end of the numbers seem to be.......... 9A5 or 8A5
Anyone have number like this ?
Thanks guys !
Old Apr 16, 2011 | 09:30 PM
dcbaker's Avatar
The block numbers are cast right into the block and are on both sides. At least mine is. My block is a 55. The dreaded cracking block is a 53. The numbers are about an inch high.
2001 2500 SLT QC CTD, Auto, Stock
Old Apr 16, 2011 | 09:49 PM
Purplezr2's Avatar
Some blocks don't have a number cast in the normal spot, its higher and just a series of number and letters, these are Mexican blocks not the Brazil blocks that had the large letters stamped on the side.
Info from here
Old Apr 16, 2011 | 10:54 PM
440727's Avatar
Where are they normally located on the passenger side ?
Thanks guys !
Old Apr 17, 2011 | 05:38 AM
Purplezr2's Avatar
I believe mine were behind the vaccum pump, if i remember right.
Old Apr 17, 2011 | 09:09 AM
440727's Avatar
Thanks !
Old Apr 17, 2011 | 01:13 PM
SIXSLUG's Avatar
I don't think the Mex blocks have a passenger side id. The mex #'s are about 1/4" size and kinda hard to read.
The Mexican blocks are considered the best for longevity and reduced wear.
Old Apr 17, 2011 | 11:39 PM
440727's Avatar
What years were the Mexican blocks most common ?
Thanks !
Old Apr 18, 2011 | 12:11 PM
SIXSLUG's Avatar
Look on the vin for Mexican trucks. Its a number 3 in the first position. Likely but not always a Mexican block. You have to check the block for sure.
As for years of manufacture, I am unsure.
sCreamin400
Nov 2, 2008 01:46 PM
MDLP412
Feb 4, 2008 04:35 PM
Bubspc
Jul 27, 2007 10:32 PM
24Vford
Jan 2, 2007 11:14 AM
lovinCTD59
23
Jul 26, 2006 06:59 AM
