24 Valve no start issue.
Having a serious issue with my truck its a 1999 dodge ram cummins. So, about two weeks ago I drove it home and parked it in my driveway with the window down. Didn't realize we were going to get 5 or 6 inches of rain that night. So it rained in the drivers side soaking everything. I realized it the next morning and put all the windows down to dry it out. Came back later to use it and it started for about 3 seconds then died. Repeated this about 3 or 4 times then wouldn't start at all. I immediately assumed that my raptor lift pump had crapped out because it had been growling a little. Cracked the line on the top of the filter and bumped the starter and it ran fine and seemed to have adequate flow. Next I cracked the injector lines but couldn't get any serious fuel. I figured the injector pump was out, I even though I had replaced it once about 2010. Grabbed my tuner and looked for codes because last time it threw the injector pump code, but didn't have any codes related to the motor. Called a local diesel place to order an injector pump anyway, and told him the story and he said check for the alarm system to be activated putting the truck in lock down. I read up on that and that sounded right. I did all kinds of tricks, locking and unlocking doors with the key, then manually, then tried the auto locks which weren't working. I finally unhooked the batteries and walked away for 4 hours, came back, messed with the locks and hooked up the batteries and it fired right up. Away I went, drove it every day for a week. The only problem I had was the drivers window switch wouldn't control the window except here and there and the power locks weren't working. Once I tried to roll up the window and the dome light came on. I figured the switches were shot from getting wet.
Parked it in the shed and came out the next day to take off and went back to same problem. 3 or 4 starts for 3 or 4 seconds then no start at all. Did all the same battery disconnect and door lock things. Nothing, Replaced the drivers side window and lock switches, Nothing, Jumpered across the door lock sensor for the key, Nothing, Went to a friend and borrowed a SnapOn Solus scanner and hooked it up. No codes for the injector pump. Only one code for the motor that said reduced power because of overheat. There were other codes in the transmission and ABS but nothing that should deal with it starting. When I went to "Body" the scan tool could not communicate with the truck computer. I couldn't see codes, I couldn't run tests. I thought this was all controled by the CTM so I ordered a used one online and plugged it in and Nothing. Now I am sure I could have gotten a CTM that was already bad but what are the odds. I hooked up the scan tool again and nothing changed, I still cannot communicate with the computer for the "body" side of the truck.
It is my understanding that when the VTSS is activated it will stop the truck from starting. When things are working as they should it sends a signal to the CTM. The CTM in turn sends a "ok to start" signal to the ECU and the injector pump pushes fuel through. Am I mistaken? I am out of ideas. As a side note, the power locks, dome light, chime, etc don't work. I don't care if they work or not but I think it is connected to the starting issue. Any help would be greatly appreciated because this is my only farm truck and I can't get crap done without it.
Things like this can be difficult to diagnose through a forum... But I'm going to say from what you described so far, you have an electrical issue and likely it could be from the rain moisture which havent dried out, or there's other corrosion issues going on. These trucks are very sensitive to battery condition, cleanliness and corrosion and tightness of major electrical connections and major grounds, and if any are a problem then it can create phantom issues having you chase a problem which doesnt actually exist.
Then I'd go over all the grounds- wet=corrosion=bad contact.
Then I'd "visually inspect" all the modules and connectors that can be found. (water+electricity= bad) (green instead of silver or copper colored=bad)
A lot of times I get stuff to fix where these basics weren't done and a lot of money has already been thrown at it. (I do not complain, if you are in my region give me the truck and pay my invoice!)
Ok, I have inspected some of the wire terminals like the CTM, all the connections look really good. A local mechanic, who freely admits he is not a dodge expert, said to start with looking at the body control module since none of those functions are working. I called the dealer and they said the BCM was in the CTM which I have already replaced. Does that sound right to you? Hotwiring the IP sounds like a really good idea. I'll hit that in the morning and see what I get. Thanks
Another thing to look at is the wiring loom from the drivers door into the body.
Due to the frequent movement the insulation gets chafed and a bit of water leads to shorts.
The CTM is the "body control" on these trucks.
If you can not connect with a certain module the bus is suspect too- maybe shorted out or open.
And a factory service manual is the best investment in this situation.
(Only 35 US$ for the CD version)
Ok dudes . I am stumped . my 2002 ram3500 5.9 wont start I have checked all fuses with test lite . NO power to fuel pump I checked with test lite under by the pump relays ? . could it be a security issue the codes ore 1693---1694 HELP ALPINE TEXAS
Welcome to the forum. But dont jump in an old thread with your own question. You wont get the right help. Start a new thread about the problem and I'd be happy to help.
zeeew
11-17-2016 02:25 PM
cgoaks77
12-09-2010 09:06 AM
CoolumConst
10-11-2008 10:00 PM
