2002 no overdrive
Old Jan 19, 2015 | 06:24 PM
Notsoauto's Avatar
2002 no overdrive
My 2002 cummins auto wouldn't shift. I replaced governor pressure sensor and solenoid. Now it shifts fine but won't shift into overdrive. I also replaced the output speed sensor. What is the reason for this? I don't have any codes at this time.
Old Jan 19, 2015 | 08:22 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Try resetting the APPS. Remove both Neg Battery cables and let it set for 30 mins.
Hook the batterys back up and turn the key to the on position without cranking the starter, then turn it off. Turn it back on, off and then leave in the on position the third time. Push pedal slowly to the floor and then let it slowly back up, turn key off.
Now start the engine and see if that helped. This will reset the pedal position sensor.
That is without cranking starter on-off-on-off-on.
72demon440
Apr 27, 2007 10:45 PM
olgraybeard
Mar 24, 2003 06:32 AM
pappyman
Dec 17, 2002 06:41 PM
marsh1946
Dec 5, 2002 12:55 PM
