2002 CTD fuel pressure gauge
I want to install a full set of gauges in my '02 CTD and I was wondering how you install a fuel pressure gauge in it? Id like it after the lift pump. I have seen replacement caps for the fuel filter canister with a nipple on it for the gauge but I dont want this style. Could someone help me out with this? Maybe some pictures or part #s would be very helpful. Thanks.
Many options and opinions on this. My setup was to use the test port on the shrader valve on the VP itself. Fuel line bought from http://genosgarage.com It did require a few fittings I had to buy locally to go from a -AN fitting to 1/4 NPT pipe thread to work but it's a clean install with a needle valve to act as a snubber. I don't have pictures of the guts of the operation but have pictures of the end result. If you want pictures I could snap a few.
A pillar Boost, EGT, Trans temp
Fuel Pressure on the steering column
Good luck.
Good luck.
dodgeguy71
17
Jan 19, 2012 12:52 AM
Patriot_RAM
Oct 8, 2004 06:10 PM
