2 new codes
Old Dec 31, 2005 | 09:49 AM
muddslinger's Avatar
2 new codes
i got a code p0216 and p0602 what will caus them
Old Dec 31, 2005 | 10:12 AM
crobtex's Avatar
0216 - Injection Timing Control Circuit Malfunction
0602 - Control Module Programming Error
The 0216 is usually the dreaded VP 44 biting the dust. However, the 0602 might be causing it.?
Have you tried re setting the codes and see if they come back?
Old Dec 31, 2005 | 10:16 AM
P.J's Avatar
P.J
How many miles on the truck?
9 times out of 10 what caused it is you Lift Pump has died. When it goes, it starves the Injection Pump and then causes the Injection Pump to overheat and die.
Do a search on "Fuel Pressure", or if you really want to be dissapointed on New Years Eve, just search "p0126" or Injection Pump Failure".
Old Dec 31, 2005 | 10:23 AM
what would cause the p0602 i reset the codes and will drive it for a wile and re check iturnd the tuner back to stock toill try to get up to the dealer on tuesday [ happy new year] the first owner had taped the ip wire ill try some liquid electrical tape it goes on real smoth and try to hide it so thay might warrinty it out i can not come up with $1150 for a new ipfrom my local shop we just got a new foster child she is a special needs child so we bought her a lot of stuff times are tuff butt we are happy she loves the truck she just loves when i start it she giggels and laughs i hope not at my for buying the truck
Old Dec 31, 2005 | 10:26 AM
the dealer just put in a in tank fel pum i have 8psi at idle that sucks i know ill have to put a pusher pump in to
Old Dec 31, 2005 | 10:37 AM
AggiePhil's Avatar
Punctuation is your friend.
Old Dec 31, 2005 | 10:40 AM
crobtex's Avatar
That seems awful low for any FP. Does the dealer know it's that low?
Old Dec 31, 2005 | 10:42 AM
Shovelhead's Avatar
Administrator / Scooter Bum
I hear that's about normal for the in tank pump setup.
Dodge claims it's a higher FLOW, lower PRESSURE pump.
Most aftermarket pump builders say don't go below 10 psi at WOT.
Old Dec 31, 2005 | 01:22 PM
i cleard the codes and returned it back to stock with the tunerand drove it for 1 hour at all speeds and no code is the tuner to much for the pump or is the pump just ready to die! well i know what ill get for my birthday the hot rod pump how much are thay and who sells them i can get a stock for $1150 from the shop here in milwaukee what kind of power gain is ther with the hotrod VS the stock IP I know i ask a lot on here but thanks for all you advise
Old Dec 31, 2005 | 01:33 PM
P.J's Avatar
P.J
They're all like that from what I've read. Brand new out of the box they won't push over 10.
I think I heard they don't drop 2.5 - 4 psi like the Carters though, they stay right around 8. (still, )
Anyone else heard that one?
Old Dec 31, 2005 | 03:04 PM
crobtex's Avatar
https://www.dieseltruckresource.com/...ad.php?t=87411
Check this link for info on new IP's.
Old Dec 31, 2005 | 06:18 PM
Big Deezul's Avatar
do not waste your time on the stock reman..cost me $1000 learn from my mistake go HR!
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
StormTrooper
Mar 28, 2005 09:17 AM
