1999 full canister leaks on top.
Old Apr 13, 2011 | 08:25 PM
shoccoefarms's Avatar
fuel canister leaks from heater wires from out of the top of the canister. how does one fix this problem.
Old Apr 14, 2011 | 06:54 PM
bill50cal's Avatar
remove the heater assembly from the top. tap the hole to i/2 pipe and plug it shut. or spend $1100.00 for an up date kit.
Old Apr 14, 2011 | 09:18 PM
turbos10's Avatar
You can also simply replace the oring that is leaking....
A hydraulic shop should have the correct type of oring.
Old Apr 14, 2011 | 09:40 PM
ARIZONACLASSIC's Avatar
I've repaired leaking canisters three times now, the latest one earlier today. The first time it was just the large o-ring that is supplied with a new filter that was ripped. The second time it was the two small o-rings that are on the back of the drain valve. Today I had a truck that had a lid with stripped threads. Dodge had a new lid is stock, $22 bucks.
Old Apr 15, 2011 | 05:10 PM
fuel canister
thanks for the info. i have cleaned top of canister it seems to be coming from the plug where to red and black wire comes from out of the top of the canister.
Old Apr 15, 2011 | 07:43 PM
Copenhagenjunkie's Avatar
Read this:
https://www.dieseltruckresource.com/...el+heater+leak
tig
Nov 17, 2013 04:20 PM
abchoppers
Jan 26, 2011 05:38 AM
13bdarren
Jan 27, 2009 12:39 PM
West Coast
Jul 4, 2007 10:25 AM
j
Nov 14, 2003 09:38 PM
