1999 with 53 block
Old Jan 5, 2011 | 10:09 AM
Don Anderson's Avatar
1999 with 53 block
I am considering purchasing a 1999 with a 53 block that has cracked. If I just replace the block, can I use just about any year of the 24 valve? I can do the work myself but want to make sure that I do not run into problems with things not matching up. Thanks for any insight you can give me.
Old Jan 5, 2011 | 08:45 PM
dizzel's Avatar
you should be ok with an 01 or 02 or for that matter any 24 valve 2nd gen engine. I'm sure there will be someone who will chime in who has done this before, but at least you can start hunting around.
Old Jan 5, 2011 | 09:52 PM
rebal's Avatar
you will need to find a block with a crank sensor or you will have to get the pcm and wire harness for the motor with out a crank sensor
Old Jan 6, 2011 | 09:32 AM
99 with cracked 53 block
Told the the guy that I would buy it from him last night if he would deliver it. Really do not need another project, guess I need to start looking for a block.
Old Jan 15, 2011 | 07:48 PM
tunamike's Avatar
i too have the famous cracked 53 block in 99 freightliner rv csan i use a block from a dodge pick up and put all my internals heads electronics etc on it and work in the rv and i am not sure how to tell about the crank position sensor if i have one and or need one any help or direction would be superb
jeepnut47
Nov 17, 2014 09:35 PM
Don Anderson
Aug 31, 2009 10:50 PM
plow
Dec 28, 2005 02:42 PM
piperca
Jan 8, 2005 10:14 PM
1320
May 17, 2003 03:28 PM
