1998.5 24Valve speedo porblem
Old Feb 3, 2009 | 10:08 AM
haddixj's Avatar
I just got a truck and the speedo doenst work its a manual trans and I know the speedo sensor is in the diff is this common what does it take to replace thanks
Jason
Old Feb 3, 2009 | 11:06 AM
98whitelightnin's Avatar
It just bolts in the top of the housing. Is your ABS light on too? When mine went out the ABS light was on and the speedo went crazy. You might check all the wireing too.
Old Feb 3, 2009 | 11:15 AM
haddixj's Avatar
yes the ABS light is on to I wonder if maybe just the sensor is bad? the under side is greasy so maybe something is shorted out
Old Feb 3, 2009 | 12:03 PM
AlpineRAM's Avatar
Pull and clean it- or even better- pull rear diff cover, clean out diff housing and clean sensor from the inside. It might just have a "beard" of shavings. (By doing this you do a rear diff oil change too)
HTH
AlpineRAM
Old Feb 3, 2009 | 01:05 PM
Haulin_in_Dixie's Avatar
I am sure that Alpine is correct in Europe, but here where getting the part means running down to the dealer, go get the sensor and ten minutes installs it.... speedo fixed!
TJE
Mar 9, 2011 06:48 PM
SmokeyBear
Jun 20, 2006 12:18 AM
dieselcrazy
Feb 3, 2003 07:48 PM
