12v ve pump swap ??-help needed
im putting a ve pumped 12v in an 01. this is the second truck ive done.the first was a 2000 w/ the lift pump on the block. it had a fass installed so i left it hooked up to push fuel to the ve. worked great. this 01 has an in tank lift pump. can i use it supply fuel to the ve and not run the mechanical pump? does it push fuel constantly? how much fuel pressure? i would like to use the in tank pump for supply. if this wont work do i need to remove the in tank pump so the mechanical pump doesnt have to pull through it? help appreciated.thanks
I think you;ll need to use an aftermarket pump like the FASS to supply the pressure needed for the VE. The intank pump is going to be pushing only a few pounds. Check the pressure requirements on the VE.
vachand
Apr 29, 2011 08:39 AM
STACKED
14
Oct 5, 2010 03:08 PM
03CumminZ4X4
Feb 1, 2008 11:15 PM
cumingetsome98
Mar 21, 2006 09:04 PM
