1-2 shifting issues
1-2 shifting issues
im having a delayed 1-2 shift. It dosent always do it, typically after i get on it pretty hard.
Its not shifting into second, even after i let off the throttle. i checked and adjusted the outside band, changed the speed sensor, and checked/adjusted my TV cable. whats next guys...
How far in is the adjuster for the front band?
(Maybe take a picture)
It may be that the band is worn off, and does not hold anymore, driving like this can and will destroy the front drum.
You could also do a pressure test, looking if the 2nd gear test port gets the correct pressure when you expect the upshift.
Brendan
Oct 17, 2007 11:12 AM
Timberman
Sep 15, 2006 08:15 PM
Dodgezilla
Jan 23, 2005 04:14 PM
