02 ram diesel p0112 & p0237 help
i need help i have an 02 dodge 2500 4x4 diesel 5sp p0112 IAT sensor low voltage p0237 map sensor low voltage. cleaned motor grounds cleaned chassy grounds checked plugs used dielectric grease on plugs changes IAT senser and map senser checked and cleaned tps replaced tps no luck check engine light is still on same cods have no throttle spent to much money all ready truck is at dodge right now they think it is the pcm any help would be great. thanks
Did you get it fixed ???
jl4c
15
Dec 5, 2008 05:32 PM
mstocktill
Dec 20, 2005 09:40 PM
