'01 Front end work
'01 Front end work
My truck has low miles on it now and feels good...but I'm also concerned about the front end items and when they should be serviced, as I've been reading seems like over time this area of the truck needs to be given some attention... so far I've looked into certain parts which I was hoping you guys could give me some advice on both service interval and replacement alternatives (from stock if better):
1) Upper and lower balljoints
2) stering stabilizer
3) track bar upgrade (heard that the '03 nd up conversion is a good way to go on these)
4) control arms
Did I miss anything, like bushings or something that are prone to being replaced (maybe with a better alternative?)
Rip Rook's Source Automotive is a place that has some parts for the above...there may be other places...
any advice would be appreciated...thanks
4) control arms
I went with all Moog parts on my front end. Balljoints,trackbar, and tierods. For a steering stabilizer I put on a Rancho. In the future I might upgrade to the 3rd gen trackbar. The good thing about Moog parts is their lifetime warranty.
Moog is good stuff; if so then worth looking into for lifetime warranty (which hopefully the parts will be good enough not to need it, for at least a long while)
not going to lift or lower the truck; I like the stock height and stance. If the bushings go bad think it'd be good to get some nice aftermarket replacements with a stiffer bushing than stock for security? Can you replace bushings w/out replacing the control arm; on some cars you can't and on some you can...dunno about our trucks?
good tips...you also mentioned you did tierods which I didn't have on my list...what are the first things to go bad? tierods? upper/lower ball joints? or what else? and at around what mileage? I'm trying to come up with a plan for servicing the front end that makes the most sense in terms of what needs replaced when and what would be easy to upgrade at the time so I don't have to do those parts soon thereafter.
Well the parts are guaranteed for life. If you keep your recite that's about $850 you won't have to spend again. And i hear that the 2ND gens are very hard on the front end. So it's possible you'll be replacing them down the road again. And maybe again.
http://www.solidsteel.ca/Trackbar.htm
Don't know who carries this in your area, but I do know its fruitless to try to contact solidsteel directly.
Your inquiries will come to fruition if you use www.solidsteel.biz
That is russell's site, and he does and will answer any and all questions relating to his product. He is excellent to deal with, really easy going fellow.
Marv Windecker is no longer associated with the guys who build and sell the solid steel products, and has not been for several years now.
I have dealt with Russell extensively, and I can tell you that you won't find a more stand-up guy when it comes to the products that he builds and sells.
Good luck with your front end parts
