01 3500 has a bad knock
Old Apr 15, 2013 | 04:36 PM
BigDodgeDaddy's Avatar
i was coming up interstate today and my truck started to run a little rough at an idle but once you throw a little fuel to it the noise stops! i just replaced radiator so i thought waterpump maybe now i have it tore down its not the water pump it sounds like its behind the timing cover any ideas on what this may be? i got to get this thing fixed its the only wheels ive got this far away from home
Old Apr 16, 2013 | 12:00 PM
Redlinear's Avatar
Fan hub?
Old Apr 16, 2013 | 12:49 PM
not the fan hub because it blowed out 3 years ago ad i deleted it and went to twin electric fans
Old Apr 16, 2013 | 03:28 PM
lovinCTD59's Avatar
You can try cracking the injector lines one at a time.. This should help you isolate which injector/cylinder has a knock.
My engine started knocking real bad a few months back. If I cracked the #1 injector line at the head the knock qould go away 100%. I had that injector tested and it failed. I replaced the injector and all is well now.... How many miles on the truck???
Zee
Mar 23, 2010 09:54 PM
HappyGA
15
Oct 16, 2006 08:21 AM
Hoss
30
Oct 3, 2006 02:57 PM
sinwagon2500
16
Jan 10, 2004 01:34 PM
