Quad rail pressure gauge
Old Oct 24, 2008 | 11:22 AM
smokintwins's Avatar
I have the quad rail pressure gauge and i am on my 4th warranty replacement,they tell me that is newer model. But each time it has went out the truck will start sounding like it is spark knocking or missing. Have read where can take out cp3 sensor. Have checked to make sure I have a good ground, do I take their word on new model or switch to Dpricol gauge.
Old Oct 25, 2008 | 09:22 PM
SuperiorRam's Avatar
also interested looks like no one knows
Old Oct 26, 2008 | 08:36 AM
Patriot2500's Avatar
There have been a couple threads about Quad rail pressure gauge issues. Use the search function and check those out.
Old Oct 26, 2008 | 12:13 PM
03 ant a hemi's Avatar
my quad pressure gauge some how caused my pressure to spike to over 20,000psi which then would detune the truck and I would loose power.
I thought it was was Edge doing this but as soon as I removed the quad it worked fine, then I hooked the quad up with out the edge and the same thing happened.
It worked good for a few months anyways. Send it back and see what happens.
Old Oct 26, 2008 | 12:28 PM
matego's Avatar
madhat's monkey boy...
Just pitch it. My quad gauge is in a box in the basement. It was fixed 2x but at least I have learned my lesson on Quad stuff. It just sucks it cost me 150$ but hey, thats cheaper than trashing your fuel system which running maxed out RP will do to you.
DiPricol or Isspro are your only 2 choices.
Old Oct 27, 2008 | 08:05 AM
UNDER-PRESSURE's Avatar
I would check the weatherpack connectors, this is what i recieved.
Old Oct 27, 2008 | 09:14 AM
jrussell's Avatar
SPA also makes a RP gauge.
Old Oct 27, 2008 | 12:25 PM
jtharvey's Avatar
How much is the SPA gauge? I seem to remember their stuff being pretty costly.
Old Oct 27, 2008 | 02:01 PM
hoffdog's Avatar
what is a good rail pressure gauge anyhow? any recommendations?
Old Oct 27, 2008 | 02:10 PM
-PowerWagon-'s Avatar
I think they are like $350ish.....but you actually get 2 gauges that actually work. I believe its RP and Oil Pressure. They are good people.
Old Oct 27, 2008 | 02:29 PM
jrussell's Avatar
Yep..."You get what you pay for" as they say.
You can use the pressure sensor for anything you like (ie. boost, oil pressure, fuel pressure, drive pressure, etc).
Bo-man
May 18, 2010 10:53 PM
Igor
Dec 27, 2008 11:42 AM
sallyman1
39
Feb 29, 2008 01:14 AM
wyocat
Dec 17, 2007 04:17 PM
subspd
Dec 24, 2006 02:01 PM
