yet again another ! headlight problems
Old Nov 9, 2010 | 04:08 PM
bigjohn92's Avatar
ive have bought 4 headlight switchs an my running light are not staying on with the headlights. so i bought a mopar headlight switch today nothing still the same old problem.i also replace the pigtail for the headlight switch new plugin soldier an heat srinked all connection old wire to new wire. so i i pull the the switch out to the first click which would be the running lights (right) nothing so i move just alittle at a time till they come back on. now im about 1/8 past where they should come on an their on wierd? but when i get to the last click no running lights just everything esle. verymad] .
Old Nov 9, 2010 | 08:47 PM
bigjohn92's Avatar
? this is the only truck i have right now to drive i need some help please i will be replacing all the light bulbs & fuses tomorrow.
Old Nov 9, 2010 | 10:23 PM
autocar56's Avatar
Just a thought probably not the problem but don't overlook the dimmer switch.
Old Nov 10, 2010 | 08:29 PM
Santaclaus's Avatar
It sounds like when you put the push rod in it isn't going all away into the lock. If I understand what you are saying is when you pull to the first click you have nothing, then as you ease it out further the parking lights come on, which is telling me this which is not moving far enough. I had this happen one time in an old Chevy. If memory serves my problem had to do with the little button you push to release the handle. Hope this helps.
Ron E
Jan 19, 2021 10:16 PM
Mpieh
Sep 21, 2010 09:05 AM
Steven K
Jun 4, 2009 10:32 AM
b84u
Feb 20, 2006 01:04 PM
Brisco
Aug 31, 2005 08:46 PM
