Wire Grimmmlin ?
Old May 28, 2023 | 05:20 PM
whosdunit's Avatar
Wire Grimmmlin ?
Here's one for ya', with ignition on, the cold-hot needle stays on the cold side, turn the ignition off and touch the brake peddle, "wham" the needle goes to "H'. Turn ignition off needle stays on "H". Now turn ignition back on the needle goes back to "C".????? Where's the short, it just stared doing this AFTER , installing my new trans., how would the install cause this problem?
coffee's ready, whosdunit.
Old May 29, 2023 | 08:37 AM
cougar's Avatar
wiring harness behind the instrument pane. had something similar with my 91.5 where the harness wore on a structural member shorting thins out.
Old May 29, 2023 | 12:18 PM
whosdunit's Avatar
Cougar, thought it might be in my ignition, pulled the covers off the steering column and found a couple of small wires that were rubbed flat (repaired), was not the ignition it's self . Will know for sure directly . Thank you for reply.
Old May 30, 2023 | 12:39 PM
whosdunit's Avatar
cougar, replaced my ignition anyway, w/ a spare from my 92 parts trk. After fixing the 2 small wires i drove around and shifted the (stiff) shifter back & forth, now the C&H gauge works normal,
Now onto the next problem, smoothing up the shifting lever (it's always something).
Silver R/T
May 13, 2014 08:05 PM
popeyesides
May 11, 2006 02:04 PM
joelsepf
Nov 11, 2005 08:34 PM
KATOOM
Apr 23, 2003 06:53 PM
