where is ignition wire for pyro?
Old May 10, 2006 | 10:20 PM
popeyesides's Avatar
Howdy,Ijust installed Issipro guages and I don't know where to hook up the ignition wire for the pyro.its on an 06.thanks..
Old May 11, 2006 | 02:19 AM
Sailpipes's Avatar
Do you mean for the lighting? I have DiPricol, not Isspro so they could be different, but I only had the two wires that hook up to the thermocouple. No ignition connections.
Old May 11, 2006 | 07:13 AM
Not for lighting.It needs power from ignition to some little box that the thermo leadwires go to.
Old May 11, 2006 | 07:25 AM
MikeyB's Avatar
I tapped mine off of the main +12v going to the electric brake controller. Doesn't hurt to have it on all the time.
MikeyB
Old May 11, 2006 | 12:44 PM
gsbrockman's Avatar
MikeyB
It's just as easy to find a 12V+ switched source (like a cigarette lighter) so why would you have it hooked to a constant source ?
Greg
Old May 11, 2006 | 01:35 PM
MikeyB's Avatar
Greg
At the time I didn't feel like removing the center bezel to access the wiring.
Now I did do it when installing the satellite radio.
MikeyB
Old May 11, 2006 | 02:04 PM
SOhappy's Avatar
MikeyB
That center bezel comes off in about 30 seconds, just remember to remove the screw behind the garbage bag/hat hook next to the glove box.
cupressus
Mar 30, 2013 09:52 AM
Stormin_Norman
13
Jun 23, 2003 12:20 AM
KATOOM
Apr 23, 2003 06:53 PM
D4Fritz
Mar 16, 2003 03:55 PM
TPilaske
16
Nov 22, 2002 08:15 PM
