where are the fueses located
Old Dec 20, 2008 | 12:23 PM
CTD2001's Avatar
I blew the dash light fuse in my 93 plow truck and i can not find the fuses anywhere, any help would be great, thanks
Old Dec 20, 2008 | 12:31 PM
fratzog's Avatar
Look under the dash, directly under the steering column. It is supposed to snap into the panel on the lower portion of the dash that has 4 screws.
Old Dec 20, 2008 | 12:32 PM
BearKiller's Avatar
The fuses are in that thing that is usually hanging by a bunch of wires right over the brake-pedal, unless some previous owner has took a grass-string and tied it to the column to get it up out of the way.
Lay in the floor and look up under the dash, immediately under the column and toward the seat; the fuse-block should be somehow tied up there.
Old Dec 20, 2008 | 12:50 PM
CTD2001's Avatar
thanks, i will go look
Old Dec 20, 2008 | 07:40 PM
CTD2001's Avatar
Found the fuse location, replaced the fuse and everything is back to normal, i would have never of found it in that location, thanks for the help
Old Dec 20, 2008 | 10:00 PM
the plow truck doesnt deserve a spot in the sig.?
Old Dec 21, 2008 | 01:03 AM
BearKiller's Avatar
Sooner or later it will find you when it comes banging down and hits you in the leg.
Those are about the shoddiest excuse for a fuse-block that I have ever seen.
It is on my list of projects to completely replace and relocate the fuse-blocks on all of our Dodges.
93beater
Apr 21, 2009 03:34 PM
GlennRMK
Apr 14, 2006 06:56 PM
Loop67
Oct 22, 2004 09:33 AM
midwestdually
Jan 3, 2004 03:44 PM
