where can i get this transmission fittings today?
I need one of these transmission fittings. Are they available anywhere but Dodge?
male thread 1/4-18 NPT
female thread 3/4-18
Part #'s???
where are they available???
Part #'s???
I broke the same thing last sunday when the trans fell off the jack. Oops... anyways i went to napa, shucks,orielies. I went every where and noone had it. So i just bought a barbed 1/4" npt fitting and a foot of transmission hose. I cut the end off the pipe stuck the hose on and away i went,
This place has them alot cheaper, your looking for a 1/2" inverted flare to 1/4 NPT.
http://www.discounthydraulichose.com...ipe_p/3202.htm
http://www.discounthydraulichose.com/
You want to be careful with certain fittings. Some have a taper at the hex end, so if the fitting gets tightened to that point it can crack the case. Common on the return line side. That fitting you have shown above does not have the taper, some do.
Totallyrad
Jul 19, 2011 07:41 AM
kd460
May 24, 2007 04:21 AM
ataboy9026
Oct 2, 2005 08:57 PM
apc
Dec 11, 2002 11:15 AM
