where to buy fuel screw
Old Jul 27, 2006 | 06:12 PM
440forPOWER's Avatar
Hello, I pulled my full fuel screw out the other day to remove the collar. After fighting with it for a couple hours I was able to remove half the collar I noticed the threads were gone where the welds were. I was having a hard time removing the collar around the welds and just decided to put it back together since I didnt feel comfortable twisting those threads or lack of into the injector pump. I dont think a die would of helped much. Someone went nuts with the welds on this one. So my ? is does anyone sell a replacement full fuel screw and if so do they sell one minus the collar?
Old Jul 27, 2006 | 06:14 PM
That would be a Bosch part. If there's a pump shop near you they should be able to get you one. The collar is installed after the pump is set up, so a new one would be unmolested.
Old Jul 27, 2006 | 06:38 PM
Thanks wannadiesel, I might have to give that a try. Later
Old Jul 27, 2006 | 07:24 PM
tboling's Avatar
Thumbs up
Scheid Diesel Service, It will be cheap
Old Jul 28, 2006 | 02:32 AM
bgilbert's Avatar
What he said, www.scheiddiesel.com.
Old Jul 28, 2006 | 09:32 AM
xtremexj's Avatar
Anybody know the Bosch part number for the fuel screw?
Old Jul 28, 2006 | 11:41 AM
gman07's Avatar
Anyone know of a way to make the screw a little longer? I need more threads before the oring. I'm pretty sure my o-ring is bottomed out on the threads in the pump, and so I'm guessing I just have a lazy pump .
Old Jul 28, 2006 | 12:32 PM
bgilbert's Avatar
IIRC, I think I've had the fuel screw out of a nonIC'd pump and an IC'd pump and they were different lengths before the o-ring. Scheid Diesel would be able to look up the part numbers and tell you if they are different numbers. extremexj, give em a call they'll fix you up.
Old Jul 28, 2006 | 01:01 PM
gman07's Avatar
That sounds great. I'll talk to them.
(I can already see the tranny going once i get a longer screw )
jmd4993
Jun 22, 2013 07:36 AM
Blowndodge
May 19, 2011 09:43 AM
loudcummmin
Oct 3, 2005 02:44 PM
Stevie G
Nov 21, 2002 10:42 PM
