1st Gen. Ram - All TopicsDiscussion for all Dodge Rams prior to 1994. This includes engine, drivetrain and non-drivetrain discussions. Anything prior to 1994 should go in here.
Ok so here is a picture of the ve on my truck but my question is what is this on it? It is the little round pice with the wire connected to it with the metal tab on it?
The little round thingy in the middle of the frame is the fuel shutoff solenoid. It should have +12v on the terminal with the key on and 0 when it's off.
So the truck won’t turn over at all it just cranks and cranks I will check and see if it has 12 volts with the key on, would some one happen to have a part number I don’t know what is the long one down lower in the left of the picture
Ok after getting home I was able to test it with a voltage tester and I am getting 11.6 volts to the tab I know it’s not 12 so what are my next options?
You can take it out and inspect the plunger on the end. If it looks ok, you can remove it, reinstall the solenoid in the pump and start the truck. You will have to use the shut down lever to kill the engine.
I tried jumping it straight from the battery and you can here it click along with do everything else sounds like it’s on the fender or something tried to start the truck after that it ran for 30 seconds then shut back down and now all it will do is crank so going to try and remove this to see if the truck runs
When you remove it there is a plunger and spring that you will remove from it then screw it back in, if it runs fine after that then the solenoid is bad and either replace it or just rig a pull cable to the manual shut down lever
I took the positive from the air dog ran a wire out and around the truck and touched it directly to the positive on the battery and boom it turned on so that not my issue I also just ordered a set of guages and a gauge pod so waiting for that to get here I removed that little black plunger had my dad touch the wire from the fuel pump as I turned the key and hoop start up repeat his process 5 times and it worked every time so I believe I need to order that solenoid,
