What is runaway, how does it happen, how do I stop it?!
Old Jan 9, 2008 | 09:36 PM
  #31
Ilikebikes's Avatar
Got somewhat of a newb question. I had one of the later model pumps that wouldn't run away, so I busted out the TIG and added some metal on the end. I turned it up farther than before (I can tell this because of the higher idle) and it still hasn't runaway. I can blip the throttle to WOT and it won't hang, it just drops down like normal. So I'm wondering, will this change at all with load on the engine? I'm just paranoid that I'm gonna be testing it and I'll leave it at WOT for a few seconds (under a load) and it will run away.
Also, if I can hold the pump at WOT just for a second without a load to test for runaway, will it change if I were to hold the pump at WOT for more than a second? I've just been running it at WOT for a second with no runaway probs yet.
Maybe I'm just paranoid because I've never had a pump that can runaway! Thanks for any advice.
Old Jan 9, 2008 | 09:47 PM
  #32
Dean Snow's Avatar
Thought I would leave another thing to add here. Before you crack on the pump and start tuning, make sure the board you are using isn't bowed. I couldn't visibly see my board was bowed. But when i used it i found out it was. it wouldn't shut the engine off. test it out and make sure it shuts off the engine by blocking the turbo with the board first. and that air cant suck in around the board. Instead of having to run around like an idiot and find another one while your engine is on its last leg of run away. Wonder what jack A** did that (yes it happened to me, man..)
Old Jan 9, 2008 | 09:50 PM
  #33
Dean Snow's Avatar
as far as i know, if it didn't run away or hang while sitting there, it inst going to run away while driving it
Old Jan 10, 2008 | 01:06 PM
  #34
Ilikebikes's Avatar
I'm pretty sure you're right. Just wanted to double check.
Old Jan 10, 2008 | 04:50 PM
  #35
He's right.
My pump is a "hanger" but it won't run away. Seems to me like you could add a little more metal to that fuel screw...
Old Jan 10, 2008 | 05:30 PM
  #36
dbrick's Avatar
Originally Posted by Jim Lane
The only engines I have ever seen run backwards were the Detroit's and all 2 strokes.
I have also seen them run with the crankshaft broken in 3 pieces because on the Detroit’s the injector is fired by the camshaft and not timed by a pump.
An inline could break into 6 smaller engines and still be running.
There is also a complicated mechanical fuel rack that throttles each injector, if the rack ever binds up the engine can run away also.
When I would set the rack I would always and check my work before I fired the engine for the just in case something went wrong.
Jim
I recently read a thread of a cummins running backwards. I'll see if I can dig it up
Old Jan 10, 2008 | 11:53 PM
  #37
Ilikebikes's Avatar
Yeah, mine won't even hang. I've got a few more threads on the fuel screw before it will bottom, but maybe I'll save those for a few days before a dyno .
Old Nov 8, 2009 | 06:58 PM
  #38
adam greene's Avatar
ok from a stock motor how many turns does it take to get a runaway
Old Nov 8, 2009 | 07:03 PM
  #39
93flatbed's Avatar
Each pump is differant. Some cannot make one run away with a stock "Power screw". Some can do it just by screwing it in a few turns. You need to play with it until you find your "happy" point.
On mine I had to pull the screw all of the way out and braze a little on the end untill I could reach "Maximum Potential". Don't forget to get a pyro before doing to much!
Good luck and have fun.
Old Nov 8, 2009 | 07:09 PM
  #40
i only turned it 2 turns from stock i dont think it will run away but i have had it at wot, if the motor is off and you pull the trottle wide open can you tell if its gonna hang?
Old Nov 8, 2009 | 07:23 PM
  #41
93flatbed's Avatar
No. It has nothing to do if the throttle it's self is going to hang up. Its if it fuels past it's point. Then you cannot stop it from fueling. What they are talking about is if the rpm's stay up after you let off of the throttle, even with the peddle cumming up off of the floor. At two turns I'd be preaty sure you are ok. Is that about a clear as Mud?
Old Nov 8, 2009 | 07:31 PM
  #42
yea as clear as mud sorry for all the ?s i just bought my 93 yesterday and have alredy started on it. im used to the 01 cummins just puttin a programmer in it and rolling on
Old Nov 8, 2009 | 07:54 PM
  #43
93flatbed's Avatar
No problem that's the reason we are all here, to learn!
Old Nov 8, 2009 | 08:10 PM
  #44
unixcowboy's Avatar
Nobody ever answered your "How do I stop it"
IF you do turn your fuel screw in far enough to hit runaway you better have a 2x6 around to put over the compressor intake .....That's the only way to stop runaway.
I ran my truck right at float - ie let off the throttle and it would kind of float a few seconds before it returned to idle -- for 6 or 7 months. No bad side effects ecxept scaring edit out of a couple kids in a powerjoke when they revved their engine and I revved mine and it didn't slow down right away
Old Nov 9, 2009 | 03:51 PM
  #45
You can get away with that with an automatic trans, but it's really annoying with a stick...
