What kind of wheel is this?
Old Nov 24, 2009 | 03:06 AM
Yukon 400's Avatar
I've been looking around for some wheels for my newly acquired 93' and was looking for some wheels and tires for it, I have some h2 wheels and tires on my 92' but this time I want something that matches the classic look better, after searching through the current wheel designs and ending up with nothing, some of the older steel spoke wheels began to appeal.
In the past there were many 60's and 70's era trucks and 3 door suburban with 8 lug steel 8 spoke wheels with a flat plate or slightly dished center. Below is one that I found in a 5 lug version. Does any one know what vehicle they came off or if it was an aftermarket manufacture tat made them and where to get some in a 16" or 16.5" wheel size. These should look good with some 37" or 38" military tires on the truck, any information is greatly appreciated.
Old Nov 24, 2009 | 07:49 AM
Totallyrad's Avatar
Kinda looks like a trailer rim.
Old Nov 24, 2009 | 08:03 AM
JEMGTX's Avatar
I had a set of those on my 1973 Power Wagon. They were from Dick Cepak (sp?). They were quite popular then, and were called 8 spoke wagon wheels.
Old Nov 24, 2009 | 08:18 AM
dart3404's Avatar
those are jackman wheels google it irc ther are out of buisness
Old Nov 24, 2009 | 12:36 PM
12valve@heart's Avatar
From what I see on Ebay, it looks like Pacer still makes them.
Old Nov 24, 2009 | 01:21 PM
dieselcrazyw350's Avatar
i have a set of those rims. i plan on putting the 36in hummer tires on them they are 16.5. i got them off like a 70's ford 4x4 that my dads friend had. here is a pic right now they have bald 33's.
Old Nov 24, 2009 | 01:33 PM
PapeCAT's Avatar
Cool deal. Are you looking at putting the Bias 36" hMMVW tires on there or the radial 37" ?
I have the 37" on mine they're great.
Old Nov 24, 2009 | 01:39 PM
i was planning on the bias 36's i was worried that the 37's wouldnt fit.
i saw the picture of your cc with the 37's looks sick!
would you be kind enough to measure the true height of those 37's for me?
Old Nov 24, 2009 | 01:45 PM
PapeCAT's Avatar
sure.
Well Come by and take a look at how they fit in mine. I don't have any issue with the fronts and you have what looks to be 2-3" more lift than I do. I lifted my rear end too high, I'm going to be removing the 3" block today, I have a 10 degree actual angle on my final driveline! (too short) but even then , the 37s fit great with no lift at all. You might need to tub out the inside of the fenders a bit though if you're going to load it a lot/squat it
Old Nov 24, 2009 | 01:50 PM
i can come over right now if you aren't busy with anything.
i dont have anything going on today.
Old Nov 24, 2009 | 02:00 PM
PapeCAT's Avatar
ok I'll be here but I have a conference call 1-1:15 ish, so you'd have to just hang out for a bit
Old Nov 24, 2009 | 02:06 PM
cool man ill be over in a few.
Old Nov 24, 2009 | 02:35 PM
PapeCAT's Avatar
I just measured the rear tires... 35" from the floor up
These are the Good Year Wrangler MT Military OZ 37" HMMWV surplus tires BTW. I got them used. They are only about 3 years old and have 95% tread. I think the Military is going with a different tire now and are pulling all the old MT tires so there are a ton available at the surplus vendors all around. They have a 3800 LB load rating at 55 psi....
Old Nov 24, 2009 | 08:56 PM
ebteckx's Avatar
man o man I love the real wagon wheels... crager has the d-window but they arent quite right... have a set of old chrome ones on my dads half ton 73 power wagon... sorry i dont have any pictures...
Old Nov 24, 2009 | 09:16 PM
bigredbrick's Avatar
I second dart3404, Jackmans had the spokes welded directly to the wheel like in Yukon 400s picture. All other (that I know of, could be wrong) spoke or wagon wheels had the holes punched out of the center section leaving a continuous rim that was welded to the wheel like shown in dieselcrazy's picture.If you clean up the wheel you might find a manufacturers name stamped on the rim.
