what kind of oil in a 5 speed manual transmission
Old Aug 29, 2012 | 05:32 PM
jj3500's Avatar
i have a 93 dodge D350. 2WD, 5.9 magnum gasoline engine. 5 speed transmission. i want to service the transmission with fluid. What type and how much do i need?
this truck new to me...no manual in truck.
thank you all in advance.
Old Aug 29, 2012 | 06:32 PM
JimmieD's Avatar
For the last 5 years I've been using Amsoil Synthetic in my NV4500 5 speed, Amsoil's Synthetic Manual Transmission and Transaxle Gear Lube 75W-90 API GL-4 MTG
I live in a mountainous area that every ride is continuous gear changing and on a couple of uphill hairpins very fast shifts are required: no problems at all with the carbon fiber synchros when using Amsoil MTG.
Had some problems with shifting after about 4 years and worried the Amsoil had failed me. Nope, my hydraulic clutch was way out of adjustment, fixed that and was right back to lightning quick shifts. Amsoil's 1/2 the price of Mopar Meritor.
https://www.amsoil.com/storefront/mtg.aspx
Old Aug 29, 2012 | 07:43 PM
93/4X4/CREWCAB's Avatar
The 93 does not have a NV4500 unless someone did a tranny swap. If I where you I would find out what the tranny is before you service it. There are many different fluids for different trannys. I would think the 93 would be a getrag but I might be wrong. If its a getrag they use 5/30 motor oil and I run synthetic in mine.
Old Aug 30, 2012 | 04:36 PM
Bencie's Avatar
No Getrags used in gassers, probably an NV4500 gasser version.
Old Aug 30, 2012 | 10:22 PM
Mark Nixon's Avatar
Definitely an NV4500 in this rig.
It would use the same lube as the '94-up diesel version, Castrol Syntorque, or the current equivalent.
Mark.
Old Aug 31, 2012 | 07:32 AM
Well I learned something because I did not know they put a NV4500 in a gas truck. Thanks
Old Aug 31, 2012 | 10:31 AM
Mark Nixon's Avatar
Just in 1992 and 1993 on the old squarebodies.
Prior to that it was the (believe it or not) A-535 Dakota tranny, if the 5 speed option was chosen.
Mark.
EverydayDiesel
19
May 7, 2010 11:40 AM
leeboy
Mar 26, 2008 11:08 PM
Burkert
21
Nov 26, 2007 07:09 PM
MossyOakGlock
18
Sep 21, 2007 03:42 PM
adamroofer25
Aug 24, 2003 02:31 PM
