What kind of Boost should I be Getting?????
Well, finally got a boost gauge on the ol' gal' but I dont know what to expect as far as boost goes? Puttering around it goes to 5psi, and when I get on it, it peaks around 16psi. It never really holds a boost reading for long---once I accelerate to a certain rpm and stay there, the boost drops until I give it more skinny pedal. This sound normal? Sitting in the driveway I dont built much boost, but under normal driving load I do....I dont know if im paranoid or what. I checked my fittings with soapy water, and checked the intercooler couplers as well-all ok. I do have a 18.5cm housing, but have a 16 on the shelf along with a pyro to go in too. Stock exhaust....
Boost sounds extremely good for a stock pickup. Most of the intercooled ones make around 12-14 psi stock from what I understand. The boost peaking during acceleration is normal. It's relative to the load on the engine. Once the RPM's get up, the engine isn't under load anymore so the boost drops. You should be VERY pleased with these results on a stock pickup!
Dan
Dan
Sounds like a strong stock truck
Time to toss in that pyro and crank 'er up
Is the truck auto or manual? Really, either way, the 18.5 isn't a bad housing and, IMO, unless you're going to a 12cm from a 2nd gen, all the hassle of removing the 18.5 won't be worth it if just going to a 16. Again, JMO.
If you have a die grinder, you can make an 18 spool like a stock 16
. I have had good luck with the ported 18s, have never run a 16. Going to my current 14 (came with the turbo) only gave me a marginal increase in spooling. AFter porting, it woke up, though.
Daniel
. I have had good luck with the ported 18s, have never run a 16. Going to my current 14 (came with the turbo) only gave me a marginal increase in spooling. AFter porting, it woke up, though. Daniel
Dan
Dan
Sweet, here I was paranoid for no reason! All that I have done to her was rotate the fuel pin 90 degrees---I was amazed how much more drivable she was after that little mod. Cant wait to get a 4" exhaust and that 16 on there.
Shouldn't his housing choice be steered by what he uses the truck for? Whether you regularly drive it fast on the interstate or spend more time dragging a loaded trailer? I thought the difference between a 12 & 18 would shine depending on use and when you wanted the extra grunt.
flatfenderjeep
Apr 26, 2009 06:38 PM
DISTURBED
Sep 20, 2007 09:41 AM
DISTURBED
Sep 19, 2007 09:20 PM
MJDiesel
Dec 2, 2006 08:59 AM
rjg23
Oct 24, 2006 07:21 AM
