What coupler would be ideal to fix this?
Old Sep 22, 2010 | 04:48 PM
The_Head's Avatar
This has always bugged me. It works, doesn't blow off, but it looks so chincy. As you can see the pipe angles down to the intercooler. What coupler should I get to have a better connection here? and where can I go online to get it? Thanks guys.
Old Sep 22, 2010 | 04:52 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
Subscribed because i have that same "thing" on my truck.
Old Sep 22, 2010 | 04:53 PM
Gots_a_sol's Avatar
Something like this?
what size piping do you need it for?
Old Sep 22, 2010 | 05:02 PM
The_Head's Avatar
Um I think it's 3" piping. It's just a standard coolertubz pipe. I got coolertubz before he invented the PS/IC kit for the first gens.
I think I just need a longer coupler?
Old Sep 22, 2010 | 06:02 PM
BearKiller's Avatar
I agree that a longer coupler would be a better fit.
I would also replace that hose-clamp with another TEE-bolt clamp.
I get that sort of stuff from Verocious Motorsports.
You could call them and explain that you need a longer than standard coupler.
Old Sep 22, 2010 | 06:21 PM
7horn's Avatar
I sent ya some links in a PM Head
Old Sep 22, 2010 | 10:46 PM
jimbo486's Avatar
Hump hose is what you want. It'll have some flex in it for just that situation.
Old Sep 23, 2010 | 06:07 AM
#2isgreen's Avatar
Unless it's untaxed, then it's red.
Is that what will happen when I go to a PS IC? Nothing about that in the PS/IC stickey!! I'm about to put mine in next weekend I guess I'll hold off till I can get a better connector or the proper "tubz". Anybody know what tim charges for that PS kit?
Old Sep 23, 2010 | 07:32 AM
The problem happens because of the straight intercooler pipe trying to go to the outlet of the d-tech turbo... its in a different place than the stock turbo so you need to tip the tube up like his picture. It makes the coupler look like crap when you do it though.
Old Sep 23, 2010 | 10:55 AM
Douglas2's Avatar
hey-Hey!!!,
One more thing on the coupler. Get one with fiberglass reinforcement. Polyester, aka mylar is at( or over ) its limit for use at the turbo and even a four-ply will be at risk. Now ov course the 'glass ones are about twice the price.
cheers,
Douglas
Old Sep 23, 2010 | 12:31 PM
Wettstein's Avatar
here is a link to his site for yea no more looking all over Flee Bay
http://www.coolertubz.com/1991_-_1993_CoolerTubz.html
Old Sep 23, 2010 | 09:01 PM
The_Head's Avatar
Thanks for the ideas everybody!
Old Sep 23, 2010 | 09:34 PM
Bencie's Avatar
What about getting the exh shop to put a slight 'S' bend in ur tube?
Old Sep 23, 2010 | 10:19 PM
92smokin blacky's Avatar
yeah i had the same deal, but it never blew off at over 40 lbs of boost so i didn't worry about it. I think if its clamped good past the ribs, then it should be fine.
Old Sep 23, 2010 | 11:42 PM
jimbo486's Avatar
It also appears that you have a 3rd gen compressor housing. If the s362 from D-Tech had the 1st or 2nd gen comp. housing with the v-banded 90* elbow, things would probably line up better. But, if it works, it works!
