What is the common size tire for 16x7 wheels?
Old Nov 26, 2007 | 11:43 PM
Firstgenfanatic's Avatar
Just wanted to know what is the most common size of tire run on 16x7 wheels? I was recently told by my local tire store that 235/85/16's are obsolete. They claim that this tire size is only popular with farmers and people who haul trailors. I realize that 235's are skinny tires.........but what size of tire would look/be most appropriate for 16x7 wheels?
Old Nov 26, 2007 | 11:47 PM
Dean Snow's Avatar
i run 285/85/16 and they look nice
Old Nov 27, 2007 | 07:59 AM
93Fury's Avatar
I think you need to find a new tire shop. Around here that's pretty much the size tire people run on duallies. More common sizes are 245 or 265/75, alot of trucks came from the factory with these sizes.
Old Nov 27, 2007 | 08:06 AM
mw66nova's Avatar
i'm running a 235/80/16 i believe...it might be an 85 series...
Old Nov 27, 2007 | 09:33 AM
Jschlachta's Avatar
I am running 285/75 16 bfg all terranes on the alcoas. best size would be 265/75 16 just a touch smaller in diameter than the 235's but wider. stock for many fords
Old Nov 27, 2007 | 12:18 PM
RAMMINVA's Avatar
Are 265/85/16 wider than 235/85/16? I thought that the 85 would be the width? I have 235/85/16 on my 16x8 weld wheels and they are pretty skinny. What would be a good next tire size i should look at getting? I'd like them wider!
Old Nov 27, 2007 | 12:43 PM
apwatson50's Avatar
I think your tire shop is on crack saying 235/85/16's are obsolete. Thats all we run. Tall skinny tires like this size will give you better mileage and better traction than a same height wider tire.
Old Nov 27, 2007 | 01:02 PM
Zarrinvz24's Avatar
305/70r16's seem to work pretty well. They only scrape every now and then when I'm goin over curbs and what not. . . .
Old Nov 27, 2007 | 01:12 PM
JD730's Avatar
285/75R16's would look nice on 16x8's.
265's are wider that 235's. For example, 235/85R16, 235 is the tread width in mm's, 85 is the aspect ratio or height of the sidewall as a percentage of the width, and 16 is of course 16 inch rim.
Here's one of many links out there that convert tire sizes.
http://www.therangerstation.com/tech...nch_Tires.html
Old Nov 27, 2007 | 01:46 PM
TruckU's Avatar
235-85/16 is the wides you can go on stock dualie wheels, factory was 215/85/16. Under heavy load the sidewalls of the 235's just touch, but not enough to scuff...
Old Nov 27, 2007 | 03:16 PM
MoparMarv's Avatar
Find a new tire shop. I did some looking around for my Alocas. Stock tires on fords with Alocas are 235/85r16. My Alocas that I have not put on the truck yet came with 265/75r16 which is probally the best fit for the slightly wider rim. I love the tall skinny look myself so I have been doing some more looking around at different sizes. The 265/75r16 are within 5% of the stock 235/85r16 from what I have found if your worried about speedo correctness. Anyother recommendations on tire sizes? I was accutally going to post the same question yesterday but was sent on a road trip with work.
Old Nov 27, 2007 | 03:31 PM
Jschlachta's Avatar
another option would be 255/85 r 16 Don't see them much in Florida but they are out west and into Canada.
Old Nov 27, 2007 | 09:31 PM
mabchewy's Avatar
I run 285/75 R16 Nitto Terra Grapplers with no clearance issues.
Old Nov 27, 2007 | 10:30 PM
DanMan's Avatar
I just had stock-size 235/85 16 Nokia Vativas put on mine.
Old Nov 28, 2007 | 01:11 AM
HAMMER_DOWN's Avatar
I'm running 255/85R16s on my stock wheels and they're a perfect fit...265s are about the widest you can go on the stock wheels, 285s should have atleast an 8" wide wheel. I have a set of 35x12.50s going on 17x9s next week...
