What axle in the rear of our trucks?
Old Dec 11, 2007 | 07:54 PM
marksmith's Avatar
Title pretty much has it. I am looking for a setup kit and master rebuild kit for our trucks. Which Dana70 is the dodge unit? The 70U??
Thanks all
Mark
PS... anyone know the best place to get a master rebuild kit for these beasts??
Old Dec 11, 2007 | 08:18 PM
CaptainChrysler's Avatar
Randy's Ring and pinion told me the only rear axle that came in ours trucks was a Dana 70U. They said they are all 32 spline, too. I am not sure how set in stone the spline count is though.
Old Dec 11, 2007 | 10:20 PM
Bookshelf's Avatar
I think W350's had a 70HD?? Also, I've heard even the SRW 70's, some are 35 spline. The best thing to do is get the numbers stamped in the axle tube, that'll tell you exactly what that axle was set up with when it was made.
Old Dec 12, 2007 | 06:17 PM
Randy's told me even a Dually was the 32 spline 70U
Old Dec 12, 2007 | 06:37 PM
marksmith's Avatar
I am contemplating trying my own carrier swap (got a powr-lok out of a 95)
There is a writeup on pirate4x4 that shows in depth how to set up a dana 70.
http://www.pirate4x4.com/tech/billavista/Gear_Setup/
Guess I'll call Randy's or Reider and get the 70U master install.
Old Dec 12, 2007 | 06:43 PM
Brutalowner's Avatar
Yup, that's right. 32.
However, while rebuilding your rear diff, you can upgrade the side gears in the Powr-Loc, or buy a Detroit for 35 spline axles. Then buy the corrisponding Yukon 35 spline chromoly axles for the correct length. Yukon also sells cut-to-length axles as well. Your spindles should accept the 1.5" dia of the 35 spline shafts. You may have to machine the last two threads or the spindle, due to the backside of the Yukon chromo shaft is thick in the cup area. Seems that every axle is a bit different.
I deal with Randy's almost every day. Excellent parts (USA) excellent service and prices.
The Pirate4x4 article is a good one, but you really, really should use a case spreader on the big Danas, to allow proper carrier bearing pre-load. Espically with a diesel.
Old Dec 12, 2007 | 07:30 PM
marksmith's Avatar
I have full intentions of using a case spreader.
I also have to find preload for the carrier. From the article I gathered .006 (to three or four good whacks with a deadblow hammer)
Old Dec 12, 2007 | 08:38 PM
I got prices on 35 spline conversion, and it was surprisingly affordable. I think you can get the cut to length axles and spider gears for under $300.
Old Dec 12, 2007 | 09:46 PM
1stGen545's Avatar
I have a 91 D350 SRW D-70U that came with 35 and my 92 W350 SRW D-70U had 32 and a 90 W250 D-70U with 32. All 1st gens are D-70U. I know the count on all of these trucks becose I have been in them and counted them myself.
Old Dec 12, 2007 | 10:41 PM
Bookshelf's Avatar
I have a Dana 70U that's 35 spl also. Before ordering slide an axle out and count the splines.
nvr-enuf
Jan 30, 2014 06:56 PM
2500Ram
Jan 22, 2008 05:49 PM
MX429
Aug 20, 2006 06:41 PM
TEDHRS
Nov 16, 2002 02:40 PM
