What is this?
What is this?
Was under my truck running trailer brake wires, and on the back of my Getrag (drivers side) i see a small solenoid looking unit on the back of the tranny with a few wires coming from it, and what looks like either a grease zerk or a bleeder. What is this?
I don't think so, I noticed that yours is a 91, is it intercooled or no? I think that the older non intercooled still had a mechanical speedo. So we may not be talking about the same thing.
When they went to the newer model they put a electric sensor in the place of where the cable would have gone.
no, mine is non ic'ed This thing is bolted to the drivers side of the tranny, with only wires coming out of it and i believe a grease zerk. its very close to the crossmember.
Mines a '92 but the part your describing sounds just like the "L" adapter that the speed sensor screws into and yes it's a grease zerk. Be easy if you put grease in the thing as it shouldn't take a lot.
On a 91 non- intercooled that IS the speedo sending unit....and if you "over grease" it, you will break the wafer-thin nut that holds it together( dont ask how I know...)
