What is this
Old Apr 26, 2007 | 06:31 PM
rconrad16's Avatar
What is this
Hi all I was doing some wiring under dash and touched this silver thing it was warm kept checking all day it and was the same I have attatched a picture sorry its a little fuzzy Its right around the steering collum its pluged into a harnes that has 1 pink wire 1 yellow and 1 yellow w red stripe it looks similar to a turn signal flasher except slimer
Does anyone know what it is and is it normal to be warm
Thanks ray
Old Apr 26, 2007 | 06:48 PM
That's the timer for the halo ring around the ignition lock. Warm is normal.
Old Apr 26, 2007 | 06:50 PM
rconrad16's Avatar
Thanks I didnt want anything to catch on fire or drain batt
Old Apr 26, 2007 | 07:11 PM
dieselJon's Avatar
So my halo ring should work?? My dad has a 90 dodge spirit that has this but I thought with mine being a truck it was just decoration.
Jon
Old Apr 26, 2007 | 07:14 PM
Caver Dave's Avatar
Wow! I just happened to be giving mine a wipe down inside this evening and got "burned" on the same thing (fiddling w/ the E-brake linkage)! Glad to know it's normal for it to other than ambient!
Old Apr 26, 2007 | 07:46 PM
Underpsi's Avatar
Just try and replace the bulb in it first if its not working
Old Apr 27, 2007 | 04:44 AM
Jim Lane's Avatar
Thanks ray
If you would have closed the driver’s door while you were watching it, it would have cooled off.
Although it does not get as hot as the courtesy lamp bulb across the back of your hand it still can leave a blister.
Jim
