weatherstrips?
weatherstrips?
hi
i would like to redo all the weather stripping in my truck when i go to paint it. where might be the best place to find everything
i found this kit, but i dont think it applies to our year trucks? is there a difference between the cab of a 93 and 86?
http://www.1aauto.com/1A/Weatherstrip/-/-/1AWSK00077
thanks
Justin
thanks
Justin
don't know about the vent window seals, but this should be correct for the door and window seal kit...
JC Whitney Item Number: ZX267697
At least they were still available as of a few hours ago..
The passenger side is no longer available from Mopar.
Anybody need vent windows and gaskets for an 85 Ram Charger? Free if you just pay for postage...
Yep. The driver's side vent window seal is the only one you can get from Dodge.
You're right - but notice the year models for the kit...1980-1986. I found out the hard way that the earlier vent windows are different than ours. I bought vent windows and gaskets off eBay from an 85 Ram Charger to replace a broken window - and for the gasket. The earlier windows have a metal bracket on the bottom that the glass sits in (pic). It's wider than the glass, so the gasket has a bigger opening for it. If you use one of those, you'll have a lot of wind noise-and disappointment.
I noticed the year, but guess I've never payed attention to the diff in the vent windows. Figured Dodge didn't change much in 20yrs why would they change something so little.
Hey fellas! You need to check another source for the right side vent window gasket! It is available from Dodge. I know because I ordered it and had no problems. The price quoted in another post is in the ballpark. I suggest you find a Dodge dealer that also has an auto collision center tied into it. Give them your vin# and they can order the gaskets. If not let me know and I can check my source. The other source is Steele Rubber Products in North Carolina. They have some gaskets for our trucks but at this time not a big selection since the last time I checked. I would check with them since they might have added stuff to their list. Just Google them. I hope this helps.
