Wear sleeve install question.
Need a wear sleeve on the front of my crank, ordered seal and sleeve kit from cummins found out it's not set up like a speedy sleeve so I need the special install tool = lots of $$$$$. My 2 ideas have a tool made, less than cummins but still a lot for something I'll use a few times, #2 heat sleeve up a few hundred degrees in the oven to expland it and hope the hardness of the sleeve is not affected. Open to any and all ideas. Thanks in Advance.
From: A 5th dimension, beyond that which is known to man.
What is the sleeve made out of? I see some engine builders will put a harmonic balancer in boiling water for a while to get it to expand so it will slip over the snout of a crank.
When I installed mine I had to take the rad off just to get some clearance, but once I did that I was able to tap it on with a block of wood. Once I had it centered on the snout I think I drove it on using a piece of pvc pipe...I also chilled the crank in an ice bath for a couple of hours and heated the sleeve up in the oven to 500 deg....get it on quick before it cools down!
It's a hardened steel sleeve, I think the heat and pray method is the one I'll try. Thanks
6spd05Dually
May 12, 2011 09:44 PM
Boondock
Apr 29, 2005 06:08 PM
