Wast gate question
Old Apr 6, 2006 | 07:38 PM
Mike E.'s Avatar
Wast gate question
Right now I have my wast gate disconnected. I have a 14cm housing and can produce about 20psi boost. I'm going to install new injectors in the future and I know this will raise my boost . At what psi should l set the wast gate?
Thanks
Old Apr 6, 2006 | 07:46 PM
hotmopr's Avatar
35 is a good place. If ya add enough fuel to get it there..
Old Apr 6, 2006 | 07:50 PM
rockjeep73's Avatar
Seeing as you have a WH1C I would recommend 28-30psi. Its not gonna run any cooler with more than that.
Old Apr 6, 2006 | 08:28 PM
Mike E.'s Avatar
The 14cm housing w/ wast gate came with the banks stinger plus sustem. I thought the H1C starts to get real hot in the high 20s
Old Apr 7, 2006 | 06:34 AM
G1625S's Avatar
I have the best luck at around 30 psi with my h1c. It's a compromise. 20psi is about the max for efficient, cool boost, but it's just not putting enough volume (in my case) through to burn the fuel. Though 30psi is starting to heat the air pretty good, it actually slows the pyro down more than 20psi does. Above 30, it seems to swing back out of my favor...
dodgemandan
Oct 23, 2007 02:36 PM
12valve
Dec 23, 2005 09:47 AM
ox
Apr 27, 2003 12:26 PM
ox
Jan 8, 2003 08:41 PM
