vacume pumps 89-90 to 91-93 whats the differences
Old Feb 19, 2012 | 04:56 PM
freight train's Avatar
Hi, I am in the middle of a Cummins swap and am using a 1990 motor in a 92 RC with original 92 harnesses for several reasons. Anyways, will I have any issues using the original vacume/power steering pump in the 92 truck? I noticed as I went through everything after the install that my defroster didnt seem to work. I know the vacume lines help control this stuff. Thank you for any helpful info
Old Feb 19, 2012 | 05:52 PM
simplysmn's Avatar
But doesn't the vacume line hook too the booster ?
Old Feb 19, 2012 | 06:14 PM
Yes it does. Do they work the same way? Why does the earlier model have the large diaphram on the side?
Old Feb 19, 2012 | 06:16 PM
simplysmn's Avatar
I believe they do the same thing I think the early truck's were that way and then they had to redisign them when they put the IC into the truck .
Old Feb 19, 2012 | 06:17 PM
jimbo486's Avatar
The only difference that I know of is the obvious, '89-'91 use diaphragm pumps and the '91.5-'98 use a vane style pump and have an oil supply line from the main oil galley in the block.
Old Feb 19, 2012 | 06:25 PM
Ok, thank you guys for the heads up.
NotEnufGarage
Aug 2, 2013 09:42 AM
freight train
Mar 22, 2011 08:46 PM
Kiff
Apr 9, 2009 03:29 PM
TxDiesel007
Mar 13, 2007 06:25 PM
ewatts2003
23
Aug 30, 2006 06:07 PM
