used the wrong tap
used the wrong tap
So I went to bottom tap my block today and somehow used a 12 x 1.5 tap instead of 1.75.
Found out when I pulled threads out of the block going to 90 ft-lbs. Will I beok drilling and tapping theblockfor 13 by 1.75 bolts? Or does anyone have a better idea?
P.s. I know I'm an idiot, no need to tell me now.
Found out when I pulled threads out of the block going to 90 ft-lbs. Will I beok drilling and tapping theblockfor 13 by 1.75 bolts? Or does anyone have a better idea?P.s. I know I'm an idiot, no need to tell me now.
hey-Hey!!!,
Make the decision with the tap drill requirements for bigger studs. If the tap drill isn't bigger than 12mm you're not going to get full threads out of the bigger size you'll be going to.
http://www.engineersedge.com/manufac...rill-chart.htm
All the 14mm threads want 12mm or bigger( getting to 13mm for M14x1 ). Even M14x2 takes 12mm tap drill. What thread are the 14mm? M14x1.5 sounds likely.
As an aside, does 14mm studs require poking larger holes in the head or head gasket, or perhaps a special gasket?
cheers,
Douglas
cheers,
Douglas
Keensurts are much stronger the heli coils little more coin to spend but well worth it. A friend and I did this to his 99 ctd he used a pawn shop torque wrench and pulled like 8 threads I think.
