turning up line presure
Old Jan 2, 2008 | 04:45 PM
92cummisw350le's Avatar
how do i turn up the line presure on my 518 i want the trans to shift firmer
Old Jan 2, 2008 | 05:35 PM
BC847's Avatar
1st Generation Admin
You'll need to pull the pan, so as to access a couple of Allen headed screws. . . . . . . give me a minute . . . .
Old Jan 2, 2008 | 05:41 PM
BC847's Avatar
If I'm not mistaken, one can adjust the pressure without pulling the VB.
For grins and giggles, read through this TransGo kit install thread and notice the last, bottom/right image found on page 5. It shows where and how to set it.
http://hometown.aol.com/gnkim/transgo1.html
Hope this helps.
Old Jan 2, 2008 | 09:07 PM
what about adjusting the tv cable i thought that is what that did. mabey i said this wroung what i want is a firmer shift from 1 to 2, its starting to get sort and i dont realy like it. what can i do to make the truck shift firmer
Old Jan 2, 2008 | 11:18 PM
TruckU's Avatar
Adjust the bands... loose bands will have a soft shift. The 1-2 adjuster is on the outside of the trans. Do a search here for "Bands"..
Old Jan 3, 2008 | 07:36 AM
j-fox's Avatar
DTT's web site has instructions to do it.
DTThttp://dieseltrans.com
Old Jan 3, 2008 | 04:46 PM
coundnt find any thing on there.
Old Jan 3, 2008 | 05:00 PM
j-fox's Avatar
Go thier web site, click on dodge, then forums then pressure adjustments.
They have a picture.
Old Jan 3, 2008 | 05:13 PM
still cant find the picture
Old Jan 3, 2008 | 05:16 PM
where is the band adjustment on the out side of the trans
Old Jan 3, 2008 | 10:54 PM
j-fox's Avatar
Lets see if this works.
The front band adjustment is above the shifter on the drivers side.
Loosen the jam nut, Snug it down, then back off 2 turns and lock the jam nut.
http://www.dieseltrans.com/phpBB/viewtopic.php?t=68
gunracer1
Feb 16, 2006 03:31 PM
kingofdodge7131
May 5, 2003 12:27 PM
kingofdodge7131
May 2, 2003 05:23 AM
kingofdodge7131
Apr 30, 2003 11:02 PM
DarrellB
Feb 6, 2003 04:08 PM
