turning a 3/4 into a one ton
Old Apr 8, 2009 | 06:33 PM
DODGE 92's Avatar
hi guys havent been around for a long time
what would be involved in turning my truck into a 1 ton truck thinkink of buing a 35 ft 4 axle trailer and doing some heavy hauling give me all opinions and ideas
Old Apr 8, 2009 | 06:50 PM
EClancy's Avatar
get something bigger than a 1-ton.
Old Apr 8, 2009 | 06:57 PM
BurrisWill's Avatar
For three thousand or something you can just start all over with a 1 ton cummins
Old Apr 8, 2009 | 06:59 PM
archer39's Avatar
i don't think there is a difference in SRW other than the listed GVW. I could be wrong though. Off topic (sorta) if your auto is stock i would invest some money in it before you start pulling heavy.
Old Apr 8, 2009 | 07:03 PM
PapeCAT's Avatar
Since he has his truck listed as a 3/4 ton REGULAR cab, he has the short frame, same as used in 1/2 ton reg cab long beds. The Crew cab and xtended cab 3/4 tons have the tall frame same as 1 ton SRW and DRW. If your truck was a 1 ton reg cab SRW it would have a super beefy frame as well....
Yah man I wouldn't mess with trying to beef up the 3/4 ton with a bigger axle. The frame is the weak link.
Old Apr 8, 2009 | 07:15 PM
DNRCustoms's Avatar
IF you are gonna do some heavy haulin, find yourself a nice one ton Dually.. They pull the heavy loads nice.. Much more stable.. Auto or stick, whatever you prefer..
Old Apr 8, 2009 | 07:52 PM
dzl_damon's Avatar
do the dually's have a bigger rear end? Dana 80 or something?
Old Apr 8, 2009 | 08:25 PM
Machinos's Avatar
Anything you might tow that needs to go on a 35 foot 4 axle trailer is gonna be wayyyy too heavy for a light duty truck.
Old Apr 8, 2009 | 08:38 PM
Richie O's Avatar
366 Spring Chicken
All 1st gens have the 70. 80's did not show up til second gen time.
Old Apr 8, 2009 | 09:11 PM
get a 3rd gen dually to pull that load GGEEZZZ.
the only diff. between a SRW 350 and 250 is maybe one leaf spring and .5 inch difference in rear brake shoe width.
Old Apr 8, 2009 | 09:28 PM
PapeCAT's Avatar
That is incorrect. If you don't have a tape measure, go out and look at the fwd shackle of the rear axle leaf springs on the two SRW trucks. The shackle will be hanging down below the bottom of the frame on the 250 and will be well within the height of the frame on the SRW 350 reg cab.
Point being, the 350 SRW has a much taller, beefier frame.
Old Apr 8, 2009 | 09:30 PM
dzl_damon's Avatar
bout to say.... frame scantling will be different
Old Apr 9, 2009 | 01:12 AM
Alwaysworking's Avatar
alwaysonDTR
my 91 350 has the short frame jsut like my 91 250, the only difference i see is the 350 did not come with factory overloads 250 did and the 250 has 4 inch rear blocks vs. the 350 6 inch blocks
Old Apr 9, 2009 | 01:15 AM
bigbaddiesel416's Avatar
From: anderson commiefornia oh ya you can keep the "change"
Originally Posted by DODGE 92
thinking of building a 35 ft 4 axle trailer and doing some heavy hauling give me all opinions and ideas
Ya right on i just finished mine tonight 20ft X 8ft deck 26ft overall 3 5500lbs axels 10,000 winch and all LED lights it was a blast
Old Apr 9, 2009 | 10:37 AM
Raspy's Avatar
In '93 the 1 ton and the 3/4 ton frames were the same. In '90 they weren't. I don't know the year they became the same but his truck is listed as a '92. Could be the same.
