turn siganls/brake lights
Old Oct 28, 2013 | 04:47 PM
BKTC's Avatar
anything that might cause these two to go out together?
Not fuses............not bulbs.........
Thanks, BKTC
Old Oct 28, 2013 | 04:57 PM
Philip's Avatar
Bed lost its ground.
Old Oct 28, 2013 | 08:32 PM
Check the connectors at the rear of the bed, as there is a harness disconnect back there under the passenger side. Ground wire was broken off, and had to bypass it.
Might also want to replace your flashers while you're at it.... or at least check to see if they work.
LAPA
Mar 26, 2013 12:20 PM
Rbhart
Mar 1, 2013 08:34 AM
polaris800sp
Nov 13, 2008 05:35 PM
